01-09-2020 09:21 AM
I'm using Alveo U50 in vivado block design flow. When I press generate RTL kernel to generate the kernel and return to Vitis, I can see the part is xcu50-fsvh2104-2-e.
Design is defaulting to impl run constrset: constrs_1
Design is defaulting to synth run part: xcu50-fsvh2104-2-e
INFO: [Device 21-403] Loading part xcu50-fsvh2104-2-e
But in Vitis setting, in the detail of the U50 platform, I can see the part name is "xcu50-fsvh2104-2L-e". They are different, There is a "L" extra.
So when I run the HW build, a Error will be occured. The log below is in this file:"/Emulation-HW/binary_container_1.build/link/vivado/vpl/vivado.log'"
INFO: [OCL_UTIL] internal step: report locked IPs
INFO: [OCL_UTIL] internal step: source .local/dr.bd.tcl
ERROR: [BD 5-683] VLNV <mycompany.com:kernel:bd_fft:1.0> is not supported for the current part.
[OPTRACE]|1039|12|ipirun.tcl|sdx_vpl|1578587032800|END|Open bd and insert kernels|
ERROR: caught error: ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
while executing
"create_bd_cell -type ip -vlnv mycompany.com:kernel:bd_fft:1.0 bd_fft_1"
invoked from within
"set bd_fft_1 [create_bd_cell -type ip -vlnv mycompany.com:kernel:bd_fft:1.0 bd_fft_1]"
(file ".local/dr.bd.tcl" line 27)
invoked from within
"source $dr_bd_tcl"
[17:23:52] Run vpl: Step create_bd: Failed
When I use U200 as the device, this will not happen. I have updated U50 platform in vitis and board list in vivado.
01-28-2020 01:37 PM
Hi @sl82976818
https://github.com/Xilinx/XilinxBoardStore/blob/2019.2/boards/Xilinx/au50/production/1.0/board.xml
the 2019.2 branch uses xcu50-fsvh2104-2-e for both u50DD and u50 production.
Xilinx made a mistake in both the Master and 2019.1 branch.
The u50 and u50DD are bistream compatible.
Could you try this repository?
M
01-09-2020 11:02 AM - edited 01-09-2020 11:03 AM
Hi @sl82976818
The board files on our github board repo define the u50 as xcu50-fsvh2104-2L-e.
Your Vivado project should point at these board files instead of what it is doing by default.
Here is the board repo: https://github.com/Xilinx/XilinxBoardStore/tree/2019.1/boards/Xilinx/au50
You can use these TCL commands to set the current Vivado instance to the board repo you just downloaded
set projName "your project name (in quotes)" set projDir "./$projName" set projPart "xcu50-fsvh2104-2L-e" set projBoardPart "xilinx.com:au50:part0:1.0" set_param board.RepoPaths /use_the_absolute_path/1.0 get_board_parts create_project $projName $projDir -part $projPart set_property board_part $projBoardPart [current_project]
The board file will have the correct value for projPart and projBoardPart
<component name="part0" display_name="XCU50 FPGA" type="fpga" part_name="xcu50-fsvh2104-2L-e" pin_map_file="part0_pins.xml" vendor="xilinx" spec_url="http://www.xilinx.com/u50">
part_name = projPart
projBoardPart = vendor:name:(component)name:version (Values are found in board file)
01-10-2020 06:14 AM
Hi mcertosi,
The above TCL commands will create a new project. I´m using a RTL kernel wizzard template so it can´t be a new project.
Is there some way to change board-part in the same project?
No matter I put the au50 board file into "vivado/data/boards" or using "set_param board.RepoPaths /use_the_absolute_path/1.0" I never can see the correct u50 downloaded fron github in the list of "setting/device/boards".
01-10-2020 09:40 AM
Hi @sl82976818
Feel free to use any combination of the TCL commands. They do not need to be issued in sequence.
Were you able to download the board files?
I was under the impression that the RTL kernel wizard was board agnostic.. Can you send me some screenshots of what is preventing you from using set_property board_part $projBoardPart [current_project] to change the board in the RTL wizard flow?
M
01-13-2020 08:46 AM
I only used the menu/tools/Download lasted board and installed the .deb from U50 website. I don´t know which of them downloaded the wrong board part.
Finally I have solved the problem. I have downloaded the board file then redirected the setting/Board Repository to it. then choose again U50 board, it was fine.
Thank you.
01-27-2020 07:53 AM
We finally got a U50DD board. So this problem returned to the beginning:
In the boardstore, the au50/es/1.0 contains the u50dd archives, in au50/es/1.0/board.xml describes the board is u50dd, the part is part_name="xcu50-fsvh2104-2-e".
But using "xcu50-fsvh2104-2-e" in vitis HW emulation build will cause a error. "ERROR: [BD 5-683] VLNV <mycompany.com:kernel:xxxxxxx:1.0> is not supported for the current part."
Is there some solution?
Do you want me open a new ticket for this topic?
Thank you.
01-27-2020 02:19 PM
Hi @sl82976818
Why are you choosing the ES over the Production board files?
https://github.com/Xilinx/XilinxBoardStore/blob/2019.1/boards/Xilinx/au50/production/1.0/board.xml
The board.xml in the production board files point to "xcu50-fsvh2104-2L-e"
Would that work?
M
01-27-2020 11:22 PM
Hi mcertosi,
Because the ES marked U50dd which has part name xcu50-fsvh2104-2-e , and prodection marked U50 which has part name xcu50-fsvh2104-2L-e.
So, in vivado board flow U50dd can be connected to 2 SFP port. U50 only one QSFP port.
But with U50dd can´t be used in vitis after compiled into ".xo". Maybe because the "xilinx_u50_xdma_201920_1" shell is only used for u50, "xcu50-fsvh2104-2L-e".
I have tried to modify the part name to "xcu50-fsvh2104-2L-e" for U50dd in board.xml and all others files, then used "set_property board_part" to point to this repository. Nothing changed...
So how can u50dd be used as an acceleration card in vitis?
01-28-2020 01:37 PM
Hi @sl82976818
M
01-28-2020 11:47 PM
Hi mcertosi,
YES, this is right.
I used 2019.2 replaced the board downloaded automatically, It works now.
Thank you!
10-28-2020 07:30 AM
Hi everyone,
I dont see the u50 in the board store anymore.
All the links above to github takes you to "page not found".
Anybody know how I can get the u50 board part in my setup?
10-31-2020 11:34 AM
Looks like the U50 board/part is back in Vivado 2020.1.1.
Might just be missing in vivado 2020.1
11-03-2020 08:37 AM
Hi @cmorsing ,
Good to hear you are able to find the board in 2020.1.1. You can also acquire the board files from the Vivado Lounge: https://www.xilinx.com/member/alveo-vivado.html
You'll need to fill out the survey and request access, once granted, you'll have access to the board files and constraint XDC.
Best,
-Emery
