setup issue of alveo U250 with "Getting Started with Alveo Data Center Accelerator Cards " document
Hi!
Nowdays I am working with alveo U250.
So I am working with "Getting Started with Alveo Data Center Accelerator Cards " document.
I think I did everything that document tell me.
1. sudo apt install ./xrt_201920.2.3.1301_18.04-xrt.deb
2. sudo apt install ./xilinx-u250-xdma-201830.2-2580015_18.04.deb
3. sudo /opt/xilinx/xrt/bin/xbmgmt flash --scan
[sudo] password for furiosa:
Card [0000:01:00.0]
Card type: u250
Flash type: SPI
Flashable partition running on FPGA:
xilinx_u250_xdma_201830_2,[ID=0x000000005d14fbe6]
Flashable partitions installed in system:
xilinx_u250_xdma_201830_2,[ID=0x000000005d14fbe6],[SC=4.2.0]
4. sudo lspci -vd 10ee:
01:00.0 Processing accelerators: Xilinx Corporation Device 5004
Subsystem: Xilinx Corporation Device 000e
Flags: bus master, fast devsel, latency 0
Memory at d2000000 (64-bit, prefetchable) [size=32M]
Memory at d4000000 (64-bit, prefetchable) [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [60] MSI-X: Enable- Count=33 Masked-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [1c0] #19
Capabilities: [400] Access Control Services
Capabilities: [410] #15
Kernel driver in use: xclmgmt
Kernel modules: xclmgmt
01:00.1 Processing accelerators: Xilinx Corporation Device 5005
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at d0000000 (64-bit, prefetchable) [size=32M]
Memory at d4020000 (64-bit, prefetchable) [size=64K]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Capabilities: [60] MSI-X: Enable+ Count=33 Masked-
Kernel driver in use: xocl
Kernel modules: xocl
I think everything is okay. (xrt, device)
but when I ran this command, I got this message.
5. sudo /opt/xilinx/xrt/bin/xbutil validate
INFO: Found 1 cards
INFO: Validating card[0]: xilinx_u250_xdma_201830_2
INFO: == Starting AUX power connector check:
AUX power connector not available. Skipping validation
INFO: == AUX power connector check SKIPPED
INFO: == Starting PCIE link check:
LINK ACTIVE, ATTENTION
Ensure Card is plugged in to Gen3x16, instead of Gen3x8
Lower performance may be experienced
WARN: == PCIE link check PASSED with warning
INFO: == Starting verify kernel test:
XRT build version: 2.3.1301
Build hash: 192e706aea53163a04c574f9b3fe9ed76b6ca471
Build date: 2019-10-24 20:05:16
Git branch: 2019.2
PID: 8197
UID: 0
[Thu Dec 19 20:30:31 2019]
EXE: /opt/xilinx/xrt/bin/xbutil
[XRT] ERROR: Can't reach out to mgmt for xclbin downloading
[XRT] ERROR: Is xclmgmt driver loaded? Or is MSD/MPD running?
[XRT] ERROR: See dmesg log for details. err=-110
ERROR: Failed to download xclbin: verify.xclbin
ERROR: == verify kernel test FAILED
INFO: Card[0] failed to validate.
ERROR: Some cards failed to validate.
Is it something I should care about? What can I do?
please help me.
thanks
Can you please post output of "dmesg" and "xbutil query"?
Thanks Ivank33.
I figured out this problem with this command.
rmmod xclmgmt
modprobe xclmgmt
I had the same error
please what are the steps for solving it ?
@eng_karim
If you are encountering the same error - it means that for some reason the xclmgmt driver is not loaded correctly.  Please use the following commands to reload the driver (alternatively a warm reboot should do the trick):
rmmod xclmgmt
modprobe xclmgmt
@bethe
Worked for me by doing the following
rmmod xocl
rmmod xclmgmt
modprobe xocl
modprobe xclmgmt
We are having this same issue with "board not found". But it happens whenever there is a power outage to the PC. The past few times we've been able to fix it temporarily until there is another power outage and then it happens again. Is there a more permanent solution?
Hi @cceev ,
Is the temporary fix to rmmod/modprove the xrt drivers? If not, could you please post a new topic so we dont derail this one, and we can help you there?
Best,
-Emery
