u280: Loading bit stream results in labtools 27-3176 error.
I tried to build github open source toe for alveo and generated the bit stream. But when i try to load the bit stream it results in labtools 27-3176 error which says "Check the hardware_server is running and connectivity to the target" but there is connectivity issue since other bit stream worked properly.
If anyone has any resolution please let me know.
thanks and regards,
Ishtiyaque
i.shaikh@tcs.com
Re: u280: Loading bit stream results in labtools 27-3176 error.
Hi i.shaikh@tcs.com
if you are loading an Sdaccel or Vitis example project onto a card you shouldn't need to program via the hardware manager.
Could you provide more details?
What worked, what is different now?
What shell?
What XRT?
What server? what operating system? which kernel?
How do you try and load the bitstream?
M
