benedetto73
xbutil validate fails after U280 first flashing
After first Alveo U280 flashing (see here for trouble doing that), the "xbutil validate" fails.
Is it something I should care about?
What can I do?
betto@mfgs2:~$ sudo /opt/xilinx/xrt/bin/xbutil validate -d 0000:01:00.0
INFO: Found 1 cards
INFO: Validating card[0]: xilinx_u280_xdma_201920_1
INFO: == Starting AUX power connector check:
INFO: == AUX power connector check PASSED
INFO: == Starting PCIE link check:
LINK ACTIVE, ATTENTION
Ensure Card is plugged in to Gen3x16, instead of Gen3x8
Lower performance may be experienced
WARN: == PCIE link check PASSED with warning
INFO: == Starting verify kernel test:
Host buffer alignment 4096 bytes
Compiled kernel = /opt/xilinx/xsa/xilinx_u280_xdma_201920_1/test/verify.xclbin
Error
Exception:
argument 1: <type 'exceptions.TypeError'>: Don't know how to convert parameter 1
FAILED TEST
ERROR: == verify kernel test FAILED
INFO: Card[0] failed to validate.
ERROR: Some cards failed to validate.
Tags (2)
bethe
Hi @benedetto73
It looks like you may potentially be running into the issue described at this answer:
https://www.xilinx.com/support/answers/73055.html
Please follow the directions found there to ensure you have the correct pyopencl versions installed.  Please note that you may need to do a warm reboot after getting the Hardware Platform re-installed, and/or manually attach the drivers as described here:
https://forums.xilinx.com/t5/Alveo-Accelerator-Cards/ALVEO-U200-verify-kernel-test-failed/td-p/1040992
mcertosi
Hi @benedetto73
This looks like the issue described in AR# 73055
Can you try the instructions in that link?
M
bethe
Hi @benedetto73
benedetto73
Thanks @bethe ,  the script below suggseted by @peregier inthe link you suggested actualyl works.
#!/bin/bash
/sbin/rmmod xclmgmt
/sbin/rmmod xocl
/sbin/modprobe xocl
/sbin/modprobe xclmgmt
sm7ed
thanks @benedetto73 the /sbin/... was the last and magic fix I needed to pass xbutil validate
benedetto73
Yep. I fugured as much. Thanks! ;)
It's a pity that Vitis doesn't do this by itself.
