xocl and xclmgmt cannot be found
I'm trying to install XRT but xocl and xclmgmt are not currently loaded.
I referenced the following link.
https://forums.xilinx.com/t5/Vitis-SDAccel-and-SDSoC/How-to-install-xocl-or-xclmgmt/m-p/1010729
The kernel version i'm using is 5.3.0-28-generic and ubuntu version is 18.04.3 LTS.
Is there any other way except the downgrading the kernel version?
Re: xocl and xclmgmt cannot be found
Hi @wonsikleee
I've seen users be successful compiling XRT from source to get it to work on the 5.0.x kernels.
https://github.com/Xilinx/XRT <-- Can you follow the directions under "build instructions" and let me know the results?
M
@mcertosi
I attached the image.
I removed the xrt and reinstalled it.
As shown in the file, xocl and xclmgmt cannot be found.
Hi @wonsikleee
I can't tell if you compiled the drivers from source or not.
Could you let me know what steps you took to install XRT or follow the build instructions from the github?
M
