u200 validate failed
hi I have properly installed u200 card in my server,but "xbutil validate " shows:"pcie link status failed" according to ug1301,I have closed quick boot,but still got same do you have any clue on that? thanks
Re: u200 validate failed
Hi @baronwang13146688
Can you look at the PCIe slot and tell me what it's capability is? I'd like to verify you've put the card in a gen3x16 slot.
If you can't verify the slot's capability by reading it, verify that ther eare gold pins in the pcie slot from end to end. If you cannot, then the slot is not electrically x16.
Matt
Matt
hi that really helps , thank you
It looks like the card is picking up a Gen3x8 slot, not a Gen3x16 slot.  As mentioned above, please check what slot you have inserted the card into.  If it is, in fact, a Gen3x8 slot, then there is no problem with the setup / board, the validation failed simply because a Gen3x16 slot was expected.  Operations should still complete, but you will have less bandwidth.
