Double-clicking on project file does not open it!
ISE 9.204i. When I double-click on a project (.ise) file, ISE runs, but then gives me an error message about the project file not having write permissions. If I open the project from within ISE, it's OK. The project file isn't read-only, when I check the properties from Windows.
Leon
Leon Heller
Visitor silentx
Re: Double-clicking on project file does not open it!
I had the same problems last time
Just try to put your folder in ISE folder with the other projects and open from there.
Thanks, that did the trick.
Leon
Leon Heller
I think I've found the cause of the problem - I had my project file on the desktop and ISE doesn't like spaces in directory names in some situations. I also had a problem running PACE, which disappeared when I moved the project directory into the Xilinx directory.
Leon
Leon Heller
