NgdBuild:924 - input pad net 'CLK_in' is driving non-buffer primitives:
 iam getting the following error in translate when using spartam 3. my program is  to simulate a fifo. what is this error?
     pin C on block D_0 with type FDE,
     pin C on block D_1 with type FDE,
     pin C on block D_2 with type FDE,
     pin C on block D_3 with type FDE,
     pin C on block D_4 with type FDE,
     pin C on block D_5 with type FDE,
     pin C on block D_6 with type FDE,
     pin C on block D_7 with type FDE,
     pin C on block D_8 with type FDE,
     pin C on block D_9 with type FDE,
     pin C on block D_10 with type FDE,
     pin C on block D_11 with type FDE,
     pin C on block D_12 with type FDE,
     pin C on block D_13 with type FDE,
     pin C on block D_14 with type FDE,
     pin C on block D_15 with type FDE
can any one help ?
 thanks
Re: NgdBuild:924 - input pad net 'CLK_in' is driving non-buffer primitives:
The error message is very clear.  You have an input pad that is connected to something other than an input buffer.
All external pins most either be connecting to an input buffer (IBUF) or an output buffer (OBUF).
Anonymous
Not applicable
so how to avoid this   ???
Insert and input buffer (IBUF or IBUFDS) and only connect to the signal after the input buffer.
