Visitor silentx
Problems with instantiation with Verilog (using xapp458)
I have tried to implement xapp458 which is an application to use the DDR2 SDRAM in Spartan 3A. However, for this module, vlog_xst_bl4_main_0, it clearly instantiates the following module
vlog_xst_bl4_top_0 top0
       .auto_ref_req           (auto_ref_req),
       .wait_200us             (wait_200us),
Yet as shown in the image I have attached, it doesn't allow me to add vlog_xst_bl4_top_0 module to it!
I don't get it, it works for every other module instantiating other modules. Why?
Please help!
Newbie stationary
Re: Problems with instantiation with Verilog (using xapp458)
I met the same problem. and I used Spartan-3,too
but it was OK when I used vhdl core.
Newbie mxc_smiths
I now start wondering if Xilinx had really tested these reference designs before release.
I had the same problem with XAPP458 ref design. I did the following to get rid of this issue:
commented out //`include "../source/sdramtst/vlog_xst_bl4_parameters_0.v" on each file and copied the contents of vlog_xst_bl4_parameters_0.v to the same place. So now the design passed synthesis. However, I still have problem with constraints in the provided ucf. An example:
ERROR:NgdBuild:753 - "C:/Xilinx_projects/sp3an458/source/framebuf.ucf" Line 773:
   Could not find instance(s)
   'vlog_xst_bl4_inst/infrastructure_top0/cal_top0/cal_ctl0' in the design.  To
   suppress this error specify the correct instance name or remove the
   constraint.
