Unknown Signal 1722
Hi everyone,
I am using Xilinx ISE Foundation 10.1 60-day trial. Even the simplest kind of design (3-to-2 reduction Carry Save Adder in this case) fails to simulate. It passes syntax check and synthesizes without errors. But when I try to simulate it gives me the following error:
ERROR:Simulator:798 - Unknown signal 1722 receivedPrinting stacktrace...
[0] RPCRT4.dll(RpcRaiseException+0x322) [0x77ea27b0]
[1] RPCRT4.dll(NdrClientCall2+0x13b) [0x77ef460b]
[2] NETAPI32.dll(NetWkstaGetInfo+0x92) [0x5b869acc]
[3] NETAPI32.dll(NetWkstaGetInfo+0x34) [0x5b869a6e]
[4] NETUI1.dll(WKSTA_10::I_GetInfo+0x21) [0x71ca8cc2]
[5] NETUI1.dll(NEW_LM_OBJ::GetInfo+0x24) [0x71ca8a75]
[6] ntlanman.dll(NPOpenEnum+0xb) [0x71c12705]
[7] MPR.dll(WNetOpenEnumW+0x1f1) [0x71b22d86]
[8] MPR.dll(WNetOpenEnumW+0xdc) [0x71b22c71]
[9] MPR.dll(WNetOpenEnumA+0x42) [0x71b2b302]
It repeats this kind of messages about a dozen times and then asks me to open a webcase.
I reinstalled Windows to make sure that there are no corrupted files and don't have any virus scanner to avoid any interference. From the messages it seems like there is some network issue with but I don't know why it would cause any trouble.
Jaydutt
Hi Bill,
I appreciate the quick response. I eventually figured it out. I had disabled some services (via Start > run > services.msc). I re-enabled pretty much all which had anything to do with networking except "remote registry" and "windows time." Rebooted and now it works fine.
Jaydutt
I suggest you install modelsim(Best solution) because it just works but you have to be careful and setup your modelsim.ini file correctly.  If you add your simple design to this thread someone could figure it out.
If you are in school mentor has a university program
http://www.mentor.com/company/higher_ed/program_details.cfm  if your school can't find the money for that then the next best solution is http://www.aldec.com/Resources/University.aspx
Ps. although the xilinx simulation tool is much improved it still has many issues so if you are going to be doing real designs you need a real simulation tool. Last time I tried to simulate external memory it just crashed.
Cheers,
Bill Tomb
Hi Bill,
Jaydutt
I have a different error run under Windows 7, my error shows below.
Thanks jhshukla for some tip, and I believe this solution will help someone in the future.
ERROR: Signal Unknown signal received
To overcome this error, do the following steps:
1. Start> type: services.msc
2. Enable "WebClient" only.
3. Return ISE simulation, and rerunSimulation Behavioral Model
4. This error should be minimized.
Thanks Party this works and I got the problem that the service of webclient was stop but now it starts and work correctly
Regards!
               Jahanzaib Shahid
               Ssuet Student
I have windows 7 os. ı had the same problem.
I run services.msc
and
run
webclient
it has solved my problem.
Thanx.
I did have the same error run under Windows 7,  This solution did help me and my ISE work very well
Thanks vstudio3k.
i had the same error.
tanks
thanks ,that helps !
I have the same problem but i m using windows xp plz help me
thank vstudio3k
I solved my problems thanks to your post.
I'm Hung
非常感谢,这个方法解决了我的问题!
 Thanks a lot
It worked Thank You
Anonymous
Not applicable
Thanks vstudio3k, it works
thnx alot for ur post
it h3lpzx m3 alot............................
Thanks vstudio3k... u r great :)
Hi All,
I am using xilinx10.1 ISE with windos 8 pro.
Even for small programs simulation is not working. I am getting the following error.
any one can help me
[0] [0x75a2001c]
[1] [0x75a2045b]
[2] [0x75a9a31d]
[3] [0x709f1f58]
[4] [0x709f1e0b]
[5] [0x709f21c1]
[6] [0x712b2cc3]
[7] [0x712b2b67]
[8] [0x712bafb4]
Done
[0] [0x75a2001c]
[1] [0x75a2045b]
[2] [0x75a9a31d]
[3] [0x709f1f58]
[4] [0x709f1e0b]
[5] [0x709f21c1]
[6] [0x712b2cc3]
[7] [0x712b2b67]
[8] [0x712bafb4]
Done
[0] [0x75a2001c]
[1] [0x75a2045b]
[2] [0x75a9a31d]
[3] [0x709f1f58]
[4] [0x709f1e0b]
[5] [0x709f21c1]
[6] [0x712b2cc3]
[7] [0x712b2b67]
[8] [0x712bafb4]
