How to solve cube-root problem using IP core
How to solve cube-root  problem using IP core?
Re: How to solve cube-root problem using IP core
Which core are you referring here?
Satish
Those in "CORE Generator"->"Math Functions"
We have cores which can do Square root functions only using cordic or Floating point cores and no cores to do the cube root.
Satish
Dear @atreide_lawson
We can solve the cuberoot problem with using the basic ADD, DIVIDE and SQUARE IPs available in the IP Catalog.
Consider for instance, that you want to find a cuberoot of a number C. Then, use the following equation Iteratively for say 20-50 Iterations and a fairly acceptable value can be computed.
X_(n+1) = (1/3) * [2*X_(n) + (C/(X_(n)^2))]                                        ---[1]
Here X_(n) is the initial guess of the cuberoot. For more information see the following paper:
Paper Link
Below is a simple MatLab Code for computing 3^1/3.
clear all;
c=3;
z=1.01;
for i=1:100
    z = (1/3)*((2*z) + (c/(z^2)));
end
z;
Best Regards,
Urvish
