RAM_PERFORMANCE parameter in xilinx SDP RTL template
Accepted Solution Solved
Accepted Solution
 In Tools-->Language Templates, it has RTL template for xilinx  simple Dual Port Single Clock RAM with Byte-Write. It has one parameter RAM_PERFORMANCE which can be either HIGH_PERFORMANCE or LOW_LATENCY. However, I don't find where it defines among doc or forum. Thus, I need your help to guide what they are.
All the best,
Nan-Sheng
Re: RAM_PERFORMANCE parameter in xilinx SDP RTL template
[ Edited ]
Hi @nanson,
This parameter is just for to configure if you are using a register at the output of the memory. If yes, you add one clock of latency but you can go at higher frequency.
Check UG473, optional output Registers:
Hope that helps,
Florent
All Replies
 Does anyone ever use the RTL template of BRAM inference provided by Vivado ? How do you configure the parameter ? Thanks
[ Edited ]
Hi @nanson,
Hope that helps,
Florent
