Virtex-7 block ram operation mode simulation issue
Hello
I used the virtex-7 block ram to simulation, but i don't know the simple dual-port ram port A specify no_change mode and write_first mode different.
The simulation waveform result is the same.
FPGA device: xc7v2000t
No_Change mode simulation waveform:
Write_first mode simulation waveform:
Re: Virtex-7 block ram operation mode simulation issue
Hi @quincyq2003,
There is two different things:
-> Simple Dual Port (SDP): "each port is assigned either a read or write functionality" (refer to this video: link). So the portA is configured as write port and the port B as read port.
-> Then  Write_first, read_first and No_change are write mode so they applies only on write ports so only on portA. That is the reason why the selection is greyed out for portB. And with 7-series:  "In SDP mode, the WRITE_FIRST mode is automatically mapped to the NO_CHANGE mode for power savings."
Hope that helps,
Florent
Florent
Hi @quincyq2003,
You may want to look at UG473 (link). I contains your answer ;-)
Florent
Florent
Hello @florentw
I think this is mean BRAM PORT B only fixed Write_first mode
You can also check primitive property in DCP
Thanks and Regards
Balkrishan
Hi @quincyq2003,
Hope that helps,
Florent
Florent
Visitor smattershi
according to above picture, "if the write port is in WRITE_FIRST or NO_CHANGE mode, data on the output of the read port is invalid".
But in
