Why is my asym DP BRAM not populated?
Accepted Solution Solved
Accepted Solution
[ Edited ]
I am trying to fill a "True Dual-Port Asymmetric Ram Write First VHDL" as given in UG901 Vivado Synthesis Guide. I am just changing the generics, nothing else.
RAM RTL is given below.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity asym_ram_tdp is
    generic (
        WIDTHA      : integer := 4;
        SIZEA       : integer := 1024;
        ADDRWIDTHA  : integer := 10;
        WIDTHB      : integer := 16;
        SIZEB       : integer := 256;
        ADDRWIDTHB  : integer := 8
    port (
        clkA        : in  std_logic;
        clkB        : in  std_logic;
        enA         : in  std_logic;
        enB         : in  std_logic;
        weA         : in  std_logic;
        weB         : in  std_logic;
        addrA       : in  std_logic_vector(ADDRWIDTHA-1 downto 0);
        addrB       : in  std_logic_vector(ADDRWIDTHB-1 downto 0);
        diA         : in  std_logic_vector(WIDTHA-1 downto 0);
        diB         : in  std_logic_vector(WIDTHB-1 downto 0);
        doA         : out std_logic_vector(WIDTHA-1 downto 0);
        doB         : out std_logic_vector(WIDTHB-1 downto 0)
end asym_ram_tdp;
architecture asym_ram_tdp_arc of asym_ram_tdp is
function max(L, R: INTEGER) return INTEGER is
begin
    if L > R then
        return L;
    else
        return R;
    end if;
end;
function min(L, R: INTEGER) return INTEGER is
begin
    if L < R then
        return L;
    else
        return R;
    end if;
end;
function log2 (val: INTEGER) return natural is
    variable res : natural;
begin
    for i in 0 to 31 loop
        if (val <= (2**i)) then
            res := i;
            exit;
        end if;
    end loop;
    return res;
end function Log2;
constant minWIDTH : integer := min(WIDTHA,WIDTHB);
constant maxWIDTH : integer := max(WIDTHA,WIDTHB);
constant maxSIZE  : integer := max(SIZEA,SIZEB);
constant RATIO    : integer := maxWIDTH / minWIDTH;
-- An asymmetric RAM is modeled in a similar way as a symmetric RAM, with an array of array object.
-- Its aspect ratio corresponds to the port with the lower data width (larger depth).
type ramType is array (0 to maxSIZE-1) of std_logic_vector(minWIDTH-1 downto 0);
signal my_ram                 : ramType := (others => (others => '0'));
signal readA  : std_logic_vector(WIDTHA-1 downto 0):= (others => '0');
signal readB  : std_logic_vector(WIDTHB-1 downto 0):= (others => '0');
signal regA   : std_logic_vector(WIDTHA-1 downto 0):= (others => '0');
signal regB   : std_logic_vector(WIDTHB-1 downto 0):= (others => '0');
begin
    process (clkA)
    begin
      if rising_edge(clkA) then
        if enA = '1' then
          if weA = '1' then
              my_ram(conv_integer(addrA)) <= diA;
              readA <= diA;
          else
              readA <= my_ram(conv_integer(addrA));
          end if;
        end if;
        regA <= readA;
      end if;
    end process;
    process (clkB)
    begin
      if rising_edge(clkB) then
          for i in 0 to RATIO-1 loop
              if enB = '1' then
                  if weB = '1' then
                      my_ram(  conv_integer( addrB & conv_std_logic_vector(i,log2(RATIO)) )  ) <= diB((i+1)*minWIDTH-1 downto i*minWIDTH);
                  end if;
                  -- The read statement below is placed after the write statement on purpose to ensure write-first synchronization
                  -- through the variable mechanism
                  readB((i+1)*minWIDTH-1 downto i*minWIDTH) <= my_ram(  conv_integer( addrB & conv_std_logic_vector(i,log2(RATIO)) )  );
              end if;
          end loop;
          regB <= readB;
      end if;
    end process;
    doA <= regA;
    doB <= regB;
end asym_ram_tdp_arc;
Given below is the sim screen-shot. Only PortA is being WRITTEN with data from the TB. Why I am getting those X's inside the memory? Any clues?
Testbench is here:
library IEEE;
entity asym_ram_tdp_tb is
--  Port ( );
end asym_ram_tdp_tb;
architecture asym_ram_tdp_tb_arc of asym_ram_tdp_tb is
component asym_ram_tdp is
    generic (
    port (
        enA         : in  std_logic;
        enB         : in  std_logic;
        weA         : in  std_logic;
        weB         : in  std_logic;
end component;
-- Denfine clocks
constant CLK_111M111_PERIOD : time      := 9.000 ns;
constant CLK_100_PERIOD     : time      := 5.000 ns;
signal   clk_111M111        : std_logic := '0';
signal   clk_100M           : std_logic := '0';
-- Port B
constant DATA_WIDTH_B : integer                                   := 1280;
constant SIZE_B       : integer                                   := 32 ;
constant ADDR_WIDTH_B : integer                                   := 5   ;
signal   en_b         : std_logic                                 := '0' ;
signal   w_en_b       : std_logic                                 := '0' ;
signal   addr_b       : std_logic_vector(ADDR_WIDTH_B-1 downto 0) := (others => '0');
signal   d_in_b       : std_logic_vector(DATA_WIDTH_B-1 downto 0) := (others => '0');
signal   d_out_b      : std_logic_vector(DATA_WIDTH_B-1 downto 0)                   ;
signal   addr_b_cnt   : integer range 0 to 127                    := 0              ;
-- Port A
constant DATA_WIDTH_A : integer                                   := 32  ;
constant SIZE_A       : integer                                   := 2048;
constant ADDR_WIDTH_A : integer                                   := 11  ;
signal   en_a         : std_logic                                 := '0' ;
signal   w_en_a       : std_logic                                 := '0' ;
signal   addr_a       : std_logic_vector(ADDR_WIDTH_A-1 downto 0) := (others => '0');
signal   d_in_a       : std_logic_vector(DATA_WIDTH_A-1 downto 0) := (others => '0');
signal   d_out_a      : std_logic_vector(DATA_WIDTH_A-1 downto 0)                   ;
signal   addr_a_cnt   : integer range 0 to 8191                   := 0              ;
begin
    dp_filterset_ram : asym_ram_tdp
    generic map(
        WIDTHA      => DATA_WIDTH_A,
        SIZEA       => SIZE_A      ,
        ADDRWIDTHA  => ADDR_WIDTH_A,
        WIDTHB      => DATA_WIDTH_B,
        SIZEB       => SIZE_B      ,
        ADDRWIDTHB  => ADDR_WIDTH_B
    port map(
        clkA        => clk_111M111,
        clkB        => clk_100M   ,
        enA         => en_a       ,
        enB         => en_b       ,
        weA         => w_en_a     ,
        weB         => w_en_b     ,
        addrA       => addr_a     ,
        addrB       => addr_b     ,
        diA         => d_in_a     ,
        diB         => d_in_b     ,
        doA         => d_out_a    ,
        doB         => d_out_b
    -- Generate clocks
    clk_111M111 <= not(clk_111M111) after CLK_111M111_PERIOD/2;
    clk_100M <= not(clk_100M) after CLK_100_PERIOD/2;
    -- Write RAM
    write_p : process
    begin
        en_a   <= '0';
        w_en_a <= '0';
        addr_a <= (others => '0');
        wait for CLK_111M111_PERIOD*20;
        fill_ram_1: for i in 0 to 19 loop
            en_a       <= '1';
            w_en_a     <= '1';
            addr_a     <= std_logic_vector(to_unsigned(i, 11));
            d_in_a     <= std_logic_vector(to_unsigned(i, 32));
            addr_a_cnt <= i;
            wait until rising_edge(clk_111M111);
        end loop fill_ram_1;
        en_a   <= '0';
        w_en_a <= '0';
        wait for CLK_111M111_PERIOD*1;
        fill_ram_2: for i in addr_a_cnt+1 to addr_a_cnt+1+20 loop
            en_a       <= '1';
            w_en_a     <= '1';
            addr_a_cnt <= i;
        end loop fill_ram_2;
        en_a   <= '0';
        w_en_a <= '0';
        wait;
    end process write_p;
    -- Read RAM
    -- read_p : process
        -- begin
            -- wait;
    -- end process read_p;
end asym_ram_tdp_tb_arc;
FPGA enthusiast!
Re: Why is my asym DP BRAM not populated?
I think it's because you have 2 sets of drivers on the signal array, with the potential for two sources to drive the same wire.  Normally, with 2 write ports, the BRAM memory is inferred using a shared variable array, which doesn't have any problems with driver resolution like a signal.    Try converting to a shared variable array, and see what happens.  UG901 shows an example.
All Replies
[ Edited ]
Thanks for the hint @jmcclusk.
Using shared variable it is possible to Write and Read from the RAM.
But I am sure I copied it correctly from a UG901 (v2017.1) April 19, 2017) where signal type was used.
See page 141, signal my_ram : ramType := (others => (others => '0'));  -- is used.
BUT.... There would be synthesis error because of the use of protected type.
In UG901, v2017.1 I didn't find any reference to support of protected types. I guess this is the reason why Xilinx was using using signals.
Do you have a solution for this?
FPGA enthusiast!
Long ago, it's true that shared variables could not be synthesized..   but that restriction has been lifted for many years now.
