Anonymous
Not applicable
Anyone using ABEL for programming CPLDs - I have a .dot extension problem for SR flip flops
I'm programming a Coolrunner part using ABEL.  Have been for years.  When using a SR flip flop, the documentation says that .S and .R is supported as Left side Equation values.  But, I get a compilation error:
"Logical Error 0001: Unsupported dot extension, .S, for signal SRFF1Logical Error 0001: Unsupported dot extension, .R, for signal SRFF1    Format change only..."
Anyone know what the answer is?  Never used a SR FF before in this design, but Ds work fine.  Thanks.
Sutton
Anonymous
Not applicable
What version of the tools are you using?
I would recommend opening a support case on this.
