yatinkamal
CPLD code not working
I have XCR3032XL CPLD in my design. CPLD is mainly enabling/disabling latch signals (LEDIN, OEDO) based in chip enable (CE), write, read signals from CPU. Below is the code:
 process(Addr, Wr, Rd, Reset, CE)
begin
if(Reset = '0') then
LED1 <= '0';
LED2<= '0';
endif
if( CE = '0') then
    if( Wr='0') then
       case Addr
               when "00" LEDIN <= "1110";
               when others LEDIN <= "1111";
       end case;
    if( Rd='0') then
       case Addr
               when "00" LEDO <= "1110";
               when others LEDO <= "1111";
       end case;
end if;
end process;
Please let me know what steps I need to take to make it work.
Yatin
yatinkamal
I am using IRU1206-33CY as power supply. Does this has enough current to supply XCR3032XL??
Yatin
looks like syntax error: Try the below code---
begin
LED1 <= '0';
LED2<= '0';
endif
if( CE = '0') then
    if( Wr='0') then
       case Addr
       end case;
    elsif( Rd='0') then
       case Addr
       end case;
  end if;
end if;
end process
