Newbie gdtamplaru
CoolRunner-II LED Blinking Program
Hello everybody,
I am a novice in VHDL programming so please bear with me.
I have a CoolRunner II XC2C256-7TQG144C and I am trying to make one of the 4 LEDs blink. I am using ISE 13 with a WebPack licence.
After some research I found the following code snippet which only lights up the LED, without making it blink:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity led_blink is
port (clock : in std_logic;
      a     : out std_logic_vector(3 downto 0)
end led_blink;
architecture Behavioral of led_blink is
begin
increment: process(clock)
variable i : integer := 0;
begin
if (clock'event and clock = '1') then
    if (i <= 50000000) then
        i := i + 1;
        a <= "1111";
    elsif (i > 50000000 and i < 100000000) then
        i := i + 1;
        a <= "0000";
    elsif (i = 100000000) then
        i := 0;
    end if;
end if;
end process increment;
end Behavioral;
Can someone please help me and give me an input why it doesn't blink?
Thanks in advance!
Professor
Professor
Re: CoolRunner-II LED Blinking Program
The code looks like it's trying to make all 4 LED's blink, assuming the pins are properly assigned.  Are you sure that your pin locations are correct for your board?  i.e. "clock" is on a pin actually supplied with a clock, and "a" maps to the four LED pins?
-- Gabor
Newbie gdtamplaru
Thanks for your response.
You're right, after some testing I found out that when setting the pins correctly, all 4 of them light up and stay on.
Wait, did you say that I have to assign a pin for 'clock'? How do I know which one?
Professor
Professor
The one with the clock signal going to it.  Is this a Xilinx eval board?  Those usually come with a UCF file, as well as documentation on how to use each feature of the board.  You should also be able to access the schematics for these boards.
-- Gabor
