Newbie sgt.seg
FT256 Package for Cadsoft Eagle
i need the library Package for the FT256 Coolrunner II XC2C384 in 17*17mm in Cadsoft Eagle. Need this for the Layout of a new PCB and cant find it anywhere. Would be nice if someone could help me.
Re: FT256 Package for Cadsoft Eagle
It seems like Eagle tool is not supported.
Check these threads: http://forums.xilinx.com/xlnx/board/crawl_message?board.id=CPLD&message.id=1474
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OtherSilicon&message.id=90
Vinay
Vinay
Newbie sgt.seg
Hello, thax for answering.
I know, that xilinx does not support Cadsoft eagle, but i thought here might be some withe same problem.
I also only need the package, so the pinnning is done soon, but crating the hole package is quite a lot work and with this numbers of pins a high risk to make mistakes.
Newbie sgt.seg
I found a solution.
You can use the ULP "make-symbol-device-package-bsdl.ulp" in a Eagle Library and then open the BSDL designed by Xilinx http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/device-models/bsdl-models/cplds.html and then you can create the Package and so on. It must be controlled a bit, but it seems to work perfectly!
