Visitor emilycbenz
The idcode read from the device does not match the idcode in the bsdl File.
I have been researching for hours but cannot find a solution to my problem.
I am using a Xilinx Cool Runner 2 CPLD XC2C256 TC144 speed 7C and trying to program it with a Platform Cable USB II Model DLC10. I have connected everything and there is a green light on the Platform Cable but when I try to program it from iMPACT I get the following error message.
Here is my error:
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1': Device IDCODE : 00001111111111111000111111110011
INFO:iMPACT:1579 - '1': Expected IDCODE: 00000110110101001000000010010011
PROGRESS_END - End Operation.
I have ensured that I listed the properties correctly on my Verilog code with the ISE Webpack and I have tried all baud rates.
Emily
Visitor emilycbenz
Re: The idcode read from the device does not match the idcode in the bsdl File.
Ok so my problem was solved after some careful probing.
What was happening was that the TDO line had a very slow risetime but the rest of the signals did not. Putting a 390 ohm pull up resistor on the TDO line helped quicken the risetime nad solve the problem.
Hello @emilycbenz,
Have you checked below AR
http://www.xilinx.com/support/answers/13529.html
This AR explicitly mentions workaround for older CoolRunner devices.
Ashish
Visitor emilycbenz
Thank you for your help but I tried those ideas and nothing worked.
Attached is a picture of when I scope the JTAG commands when sending a "Read Device ID" command. Yellow is TMS, Blue is TDI and Green is TCK.
Please help,
Emily
Visitor emilycbenz
Here is another picture where the Pink line represents TDO (I could not scope all 4 signals at once). Also sending "Read Device ID" command.
Visitor emilycbenz
Visitor emilycbenz
Further analysis... the pin that provided power to the jtag (Vccaux) was floating on my design so there was not adequate current causing the slow rise time in the TDO. By placing a pull up resistor enough current was drawn.
