need help to identify file format
I need help in identifying the file format of this code. I have to include it in Xilinx project but don't know which format/extension should be assigned to it. I am new to cpld.
VERSION 5
BEGIN SYMBOL
SYMBOLTYPE BLOCK
TIMESTAMP 2003 4 28 17 46 37
SYMPIN 0 -992 Input "decod1"
SYMPIN 0 -912 Input "decod2"
SYMPIN 0 -832 Input "decod3"
SYMPIN 0 -752 Input "decod4"
SYMPIN 0 -672 Input "decod5"
SYMPIN 0 -592 Input "decod6"
SYMPIN 0 -512 Input "decod7"
SYMPIN 0 -432 Input "decod8"
SYMPIN 0 -352 Input "decod9"
SYMPIN 0 -272 Input "decod10"
SYMPIN 0 -192 Input "decod11"
SYMPIN 0 -112 Input "decod12"
SYMPIN 0 -32 Input "decod13"
SYMPIN 384 -992 Output "mux0"
SYMPIN 384 -928 Output "mux1"
SYMPIN 384 -864 Output "mux2"
SYMPIN 384 -800 Output "mux3"
SYMPIN 384 -736 Output "mux4"
SYMPIN 384 -672 Output "mux5"
SYMPIN 384 -608 Output "mux6"
SYMPIN 384 -544 Output "mux7"
SYMPIN 384 -480 Output "mux8"
SYMPIN 384 -416 Output "mux9"
SYMPIN 384 -352 Output "mux10"
SYMPIN 384 -288 Output "mux11"
SYMPIN 384 -224 Output "mux12"
SYMPIN 384 -160 Output "mux13"
SYMPIN 384 -96 Output "mux14"
SYMPIN 384 -32 Output "mux15"
RECTANGLE N 64 -1024 320 0
BEGIN DISPLAY 192 -1032 ATTR "SymbolName"
    ALIGNMENT BCENTER
    FONT 56 "Arial"
END DISPLAY
LINE N 64 -992 0 -992
BEGIN DISPLAY 72 -992 PIN "decod1" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -912 0 -912
BEGIN DISPLAY 72 -912 PIN "decod2" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -832 0 -832
BEGIN DISPLAY 72 -832 PIN "decod3" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -752 0 -752
BEGIN DISPLAY 72 -752 PIN "decod4" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -672 0 -672
BEGIN DISPLAY 72 -672 PIN "decod5" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -592 0 -592
BEGIN DISPLAY 72 -592 PIN "decod6" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -512 0 -512
BEGIN DISPLAY 72 -512 PIN "decod7" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -432 0 -432
BEGIN DISPLAY 72 -432 PIN "decod8" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -352 0 -352
BEGIN DISPLAY 72 -352 PIN "decod9" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -272 0 -272
BEGIN DISPLAY 72 -272 PIN "decod10" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -192 0 -192
BEGIN DISPLAY 72 -192 PIN "decod11" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -112 0 -112
BEGIN DISPLAY 72 -112 PIN "decod12" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 64 -32 0 -32
BEGIN DISPLAY 72 -32 PIN "decod13" ATTR "PinName"
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -992 384 -992
BEGIN DISPLAY 312 -992 PIN "mux0" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -928 384 -928
BEGIN DISPLAY 312 -928 PIN "mux1" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -864 384 -864
BEGIN DISPLAY 312 -864 PIN "mux2" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -800 384 -800
BEGIN DISPLAY 312 -800 PIN "mux3" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -736 384 -736
BEGIN DISPLAY 312 -736 PIN "mux4" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -672 384 -672
BEGIN DISPLAY 312 -672 PIN "mux5" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -608 384 -608
BEGIN DISPLAY 312 -608 PIN "mux6" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -544 384 -544
BEGIN DISPLAY 312 -544 PIN "mux7" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -480 384 -480
BEGIN DISPLAY 312 -480 PIN "mux8" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -416 384 -416
BEGIN DISPLAY 312 -416 PIN "mux9" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -352 384 -352
BEGIN DISPLAY 312 -352 PIN "mux10" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -288 384 -288
BEGIN DISPLAY 312 -288 PIN "mux11" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -224 384 -224
BEGIN DISPLAY 312 -224 PIN "mux12" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -160 384 -160
BEGIN DISPLAY 312 -160 PIN "mux13" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -96 384 -96
BEGIN DISPLAY 312 -96 PIN "mux14" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
LINE N 320 -32 384 -32
BEGIN DISPLAY 312 -32 PIN "mux15" ATTR "PinName"
    ALIGNMENT RIGHT
    FONT 24 "Arial"
END DISPLAY
END SYMBOL
 Thanks for your help.
Best Regards,
Uzair
Hi gszzakacs,
you are correct its a pretty old file even more than you mentioned :) i just figured it out, its some deffinition of a symbol in cpld schematic. Thanks for your help.
Best Regards,
Uzair
I thinks its the definition of some symbol in schematic, need help to indentify its format
Professor
Professor
Where did you get this file from?
What was the original file name when you got it?
The time stamp seems to indicate that it's about 8 years old, meaning that
it's very likely to be in a format no longer supported by the newest tools.
If I had to guess, I'd say it looks like a third-party (possibly ViewDraw?) schematic
format.  In any case it only seems to have the graphic information for a symbol
but nothing of the actual logic description of the module that the symbol represents.
I wouldn't think that this file by itself would describe something you can add to
a project.
-- Gabor
-- Gabor
Hi gszzakacs,
Best Regards,
Uzair
