slow to fast clock data latching
dear all,
i want to know if there is a way to latch the serial data arriving at the coolrunner CPLD (at 115200bps baud rate) to a higher clock which FPGA expects(around 10 MHz) continuously without storing much of the data.(no flash memory used). i have 256 macro cells in the CPLD.
could anyone give suggestions for the same?
thenk you!
Re: slow to fast clock data latching
As I understand, the CPLD is clocked at 10MHz, and the data is 115200 bps.  In that case, a UART is what you need.  I beilive that Xilinx has UART code on its site.  If not, then check the web, especially opencores.com
-Dave Pollum
As mentioned by Dave, check the following link for the UART application note also you can check for the reference design in the same doc
http://www.xilinx.com/support/documentation/application_notes/xapp341.pdf
--Krishna
