Observer chenfeng5009
AXI-HWICAP
hi
how could i do partial reconfiguration using ICAP
回复: AXI-HWICAP
You mean using ICAP or HWICAP?
For ICAP, you can take a look at the tutorial ug947.
For HWICAP, check pg134, there are some simple demo about how to read and write a certain register, shifting a partial bit would be similar.
回复: AXI-HWICAP
hi iguo
  i use AXI-HWICAP for partial reconfiguration. i have read pg134,but i don't know how to use AXI-HWICAP in block design with vivado.There are any demos for block design.thanks!
回复: AXI-HWICAP
This picture is my design with AXI-HWICAP using for LED_ML_0 and LED_ML_1 ip core in block design.
回复: AXI-HWICAP
Check this:
https://www.xilinx.com/support/documentation/application_notes/xapp1099-7series-partial-reconfiguration-ssi-embedded.pdf
