Observer jsy524
CPLD Connection
Hello.
I am making transceiver board using two CPLDs, XC9572XL-VQ44.
I already made JTAG connection by connecting TDI and TDO.
I want to know whether there are other pins to connect two cplds except JTAG pins.
Thank you for your help.
回复: CPLD Connection
Can you clarify your question? You mean you have two XC9572XLs?
The two CPLDs can work totally independent; no pins need to connect together, unless you need to transfer data between them. Just connect the necessary GPIOs.
If you mean JTAG pins, and you need to put the two in one JTAG chain, you will need to connect the TCKs and TMSs together.
回复: CPLD Connection
Observer jsy524
回复: CPLD Connection
I mean I have two cplds.
I understood your reply.
Thank you.
