Cannot generate MCS file
I have 32 bit system (Linux). so I installed Vivado 2014.4 (because I read that it is the latest version that supports 32 bit).
I made a VHDL code for Half-adder.
I am trying to set up the necessary file .MCS to program a FLASH on my board.
The board is
KC705
the flash is: Linear BPI flash memory
I finished synthesis.
I generated the bitstream.
I can find the "Edit Device Properties" window and I choose "Configuration Modes" to be Master BPI-Up x16 and JTAG/Boundary Scan.
From my understanding I need to create an MCS file. I see in the tutorial here http://techmuse.in/creating-and-configuring-xilinx-fpga-with-mcs/ he gets to a window "Write Memory Configuration File" but I cannot find this item in ay of the Menus of Vivado.
Is this window started only after version 2014.4 of Vivado ?
Is there some other way to generate MCS file ? I follow the video https://www.youtube.com/watch?v=IIAZEXPlwtc. I try to do TCL command:
write_cfgmem -format mcs -interface bpix16 -size 128 -loadbit "up 0 main.bit" -file main.mcs
( I chose 128 because in UG810.pdf, it is specified that the Linear BPI flash is 128M).
But I get an error:
Vivado 12-4178: write_cfgmem -interface BPIX16 is not compatible with the main.bit configuration device settings. SPI_buswidth=1. Regenerate the bitstream with the device settings for BPI...
 When I open "Edit Device Properties" I see SPI Configuration is "NO", "NONE" and "NO". So I don't understand why it says "SPI_buswidth=1" ?
Please advise how I can create the MCS file ?
Re: Cannot generate MCS file
I thank you for your input.
There was some line in the XCD file with SPI (although not as the error message complained about).
I deleted this line from the XCD manually,
set_property PACKAGE_PIN AA12 [get_ports GPIO_SW_N]
set_property IOSTANDARD LVCMOS15 [get_ports GPIO_SW_N]
set_property PACKAGE_PIN AB12 [get_ports GPIO_SW_S]
set_property IOSTANDARD LVCMOS15 [get_ports GPIO_SW_S]
set_property PACKAGE_PIN AA8 [get_ports GPIO_LED_1_LS]
set_property IOSTANDARD LVCMOS15 [get_ports GPIO_LED_1_LS]
set_property PACKAGE_PIN AB8 [get_ports GPIO_LED_0_LS]
set_property IOSTANDARD LVCMOS15 [get_ports GPIO_LED_0_LS]
Then I run synthesis.
(Note, I saw a couple of videos that From the Tools Menu, choose Edit Device Properties handset the configuration modes to Master BPI-Up x 16, but I now I proceed without touching any of these settings).
I run Implementation.
I run Generate Bitstream.
This creates the file main.bit (in the folder HA_2/HA_2.runs/impl_1).
I go down to the TCL Console and type the command:
write_cfgmem -format mcs -interface bpix16 -size 128 -loadbit “up 0 main.bit” -file main.mcs -force
This creates an MCS file.
I choose: Hardware Manager in the Program and Debug menu (left).
I choose Open target, and select localhost:3121….Digilent… (this is the KC705 card).
I click on xilinx tcf/Digilent ….
I choose from the Tools menu (top) Add Configuration Memory Device
and select xc7k325t_0
I the list of devices I choose: 28f00ap-30t-bpi-x16 because the UG810.pdf specifies the Linear flash device as such.
I press OK,
then it asks do you want to program the configuration memory device?
I choose OK.
I choose Configuration file to be the main.MCS (it is also in the impl_1 folder)
I make sure ERASE is checked.
The device gets programmed.
End of MCS problem.
@dag1
The write_cfgmem command looks correct. You may want to add “-force” to the command to ensure it overwrites an existing version of main.mcs (see UG835 for more on write_cfgmem).
Error (12-4178) suggests that “Bitstream Settings” in the “Edit Device Properties” dialog need to be changed.  In particular, look under “Configuration Modes” and ensure you have selected “Master BPI-Up x16” and not “Master SPI x1”. See v2014.4 of UG908 near Figure 2-2 for more information on "Bitstream Settings" and on "Creating a Configuration Memory File".
Cheers,
Mark
回复: Cannot generate MCS file
It seems the tool is messed up. Did you set any configuration related properties in XDC file? If so, move them.
Secondly, open the implemented design, run 'report_property -all' and check if you have improperly set some Config properties such as SPIx1 width. Clear them all and then use write_cfgmem to create the MCS file.
returns an error
"expects exactly one object got '0'
But I solved the MCS writing problem just inserting the -force option as mentioned by one of the other persons who replied.  Thanks for your input.
I press OK,
I choose OK.
End of MCS problem.
