Newbie yoendric
Compact Flash
Please, I would appreciate advice:
I am developing a project with the Virtex 6 ML605 card. My binary file would like to save it in the CompactFlash and from there it will be executed in every FPGA boot. I would be grateful if you would instruct me in the necessary documentation to achieve my goals if possible.
Re: Compact Flash
The Compact Flash card is used indirectly by the Virtex-6 for configuration. An interceding chip--System ACE controller--reads the CF and programs the FPGA.
I assume you've checked out the board's documentation: https://www.xilinx.com/products/boards-and-kits/ek-v6-ml605-g.html
This is a good place to start: https://www.xilinx.com/support/documentation/white_papers/wp151.pdf
You should also review the V6 configuration guide: https://www.xilinx.com/support/documentation/user_guides/ug360.pdf
And then there's this: https://www.xilinx.com/support/documentation/data_sheets/ds080.pdf
-Joe G.
Re: Compact Flash
you can also check the following link which has the guidelines to program the compact flash
https://www.xilinx.com/support/documentation/boards_and_kits/xtp055.pdf
following link for creating the sys ace file
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/platform_studio/ps_c_dld_gen_systemace_file.htm
check this AR as well which has info on formatting compact flash
https://www.xilinx.com/support/answers/65024.html
