Voyager
Voyager
Difference between BITSTREAM.CONFIG.SPI_BUSWIDTH 4 and CONFIG_MODE SPIx4 ?
All the question is in the title. I'd like to configure a bitstream to use with a QSPI config flash. I know I must use the second (CONFIG_MODE SPIx4), but what is Bus Width? Could I use a Bus Width 1 with a QSPI?
Re: Difference between BITSTREAM.CONFIG.SPI_BUSWIDTH 4 and CONFIG_MODE SPIx4 ?
Hi @johnvivm
BITSREAM constraint is for write_bitstream process to ensure correct x4 (BUSWIDTH 4 ) read commands are included into bit file.
CONFIG_MODE SPIx4 is for Vivado tool to check DRC.
The advice is to match both setting to the mode you are using.
Hi @johnvivm
