Disable bitstream file read back in Vivado
I want to protect my bit stream file from being Read back through JTAG or any other way.
Is there any bit stream file security settings in vivado?
Vinay
Vinay Shenoy
Re: Disable bitstream file read back in Vivado
Hi @vinay_shenoy,
No there are no loop holes in both as concerned to readback from FPGA.
Basic setting to avoid Readback is  setting "BITSTREAM.READBACK.SECURITY"  to  Level1 or Level 2 based on your requirement.
Encryption (AES) is an advanced method of disabling the readback. here a 256 bit key will be generated for the bitstream. After the device has been programmed with the correct encryption key, the device can be configured with an encrypted bitstream. After configuration with an encrypted bitstream, it is not possible to read the configuration memory through JTAG or SelectMAP readback, regardless of the bitstream security setting.
Note : But we don't have control over the Flash or PROM. if the hacker, hacks the Bitstream through flash, there comes the importance of encryption.And encrypted bitstream will be of no use to hacker.
Deepak D N
Please reply or give kudo or Mark it as an Accepted Solution.
Hi @vinay_shenoy,
you can set this option in Bitstream settings to disable the readback. Please refer UG908 for more information. And also disable Persist option in Bistream setting.
Hope this helps.
Deepak D N
Please Reply or Give Kudo or Mark it as an accepted Solution.
Hi @ddn,
Can you please give me more insights on highlighted stuffs in Read back settings attached.
There are couple of options under drop down menu and I need some inputs in understanding them.
What is the typical settings I've to do to disable Read back?
Also, I'd appreciate if there's any hack anyone can do to retrive the bitstream info even after disabling read back in bitstream settings.
Vinay Shenoy
Vinay Shenoy
Scholar u4223374
@vinay_shenoy The obvious way to read back the bitstream is to connect to the configuration PROM directly (external on every Xilinx chip except for the Spartan 3AN and the CPLDs) and read the bitstream from that. You obviously can't disable reading the bitstream from the configuration PROM (because then the FPGA can't configure itself), and I'm pretty sure that if you can configure the chip over JTAG then you can load a bitstream that will read the contents of the configuration PROM.
The "fix" for this is encrypted boot. The FPGA has an internal encryption key that cannot be read back (with appropriate security settings) or changed, and the bitstream on the configuration PROM is encrypted with that key. An attacker could easily read back the bitstream, but with no way to decrypt it they're not going to get any benefit from it.
readback security setting set_property BITSTREAM.READBACK.SECURITY with value of Level1 (disables readback) or Level2 (disables both readback and reconfiguration).
Incase you want to reconfigure the fpga then suggested to use level1.
we would suggest you to go with the encryption of the bitstream which should help in your case
More details on this you can refer to the following link
https://www.xilinx.com/support/documentation/application_notes/xapp1239-fpga-bitstream-encryption.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp1267-encryp-efuse-program.pdf
Hi @vinay_shenoy,
below states the 3 options which you queried me from GUI:
1. Prevents the assertions of GHIGH and GSR during
configuration. This is required for the active partial
reconfiguration enhancement features.
2. Selects between the top and bottom ICAP ports.
3.Specifies whether to disable Readback and
Reconfiguration.
Note: Specifying Security Level1 disables Readback.
Specifying Security Level2 disables Readback and
Reconfiguration.
Encryption of Bitstream is also recommended.
Deepak D N
@u4223374 @ddn@kkn
Hello all, Thank you for your responses!
Is there any loopholes with readback security setting BITSTREAM.READBACK.SECURITY alone?
Why do you all recommend to go with encrypting the bitstream file?
Vinay Shenoy
Vinay Shenoy
Hi @vinay_shenoy,
Deepak D N
