Visitor sidh96
Flash SPI problem with Custom Spartan 6 board
I am working with a simple custom board using Spartan 6 XC6SLX9-TQG144. Right now i am trying to program the SPI memory that is in the board, which is a Cypress S25FL064L, and im not able to identify it in the IMPACT software (14.7 Linux Version).
I have already found information around the net about the different compatible versions of SPI for IMPACT, and i understand that the one that i am using is a more recent than the compatible one with the software (S25FL064P). I followed the example from the Cypress site and some other forums around:
https://community.cypress.com/docs/DOC-10499
https://www.xilinx.com/support/answers/11630.html (Following the Linux example)
to "bypass" the famous ID Check that wont let us program the recent memory. The thing is that i still cant program the memory because IMPACT keeps doing the ID Code Check even if i change the environment variable XIL_IMPACT_SKIPIDCODECHECK=1
I also checked the board connections and they are good (following the SPI interface from the Xilinx Documentation, page 40 to 44):
https://www.xilinx.com/support/documentation/user_guides/ug380.pdf
Does someone knows if i am missing something to succesfully program the SPI? Or another solution? I am running out of ideas...
Hector S.
Re: Flash SPI problem with Custom Spartan 6 board
where have you have set the environment variable?
you will need to set in the system variables not in the user variables.
Try this and if you see still issues then post the complet error message in impact tool
Visitor sidh96
Hi @kkn
i used the terminal. I will try what you said, thanks.
Visitor sidh96
@kkni have tried but i keep having the same error:
INFO:iMPACT - Current time: 3/28/18 12:28 PM
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00001111111111111111111111111111
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000100000000000001000010010011
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file /opt/Xilinx/14.7/ISE_DS/ISE/spartan6/data/xc6slx9_spi.cor.
'1': Downloading core...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0010 0000 0110 1000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time =      1 sec.
idcode failure error shown is for FPGA idcode, not for the SPI flash.
can you confirm you are able to configure the fpga with only bit file instead of mcs file?
check the following AR for the idcode error message you see
https://www.xilinx.com/support/answers/13529.html
Visitor sidh96
@kknyes, i can program the FPGA with the .bit file but not the SPI with the .mcs
Visitor sidh96
@kknI tried again and i got the next log:
INFO:iMPACT - Current time: 3/28/18 4:28 PM
Validating chain...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT - 0011 1100 1110 1100
'1': IDCODE is '01' (in hex).
'1': ID Check failed.
INFO:iMPACT:2488 - The operation did not complete successfully.
INFO:iMPACT - SPI Device not found.
Elapsed time =      2 sec.
hope the SPI flash interface is proper.
It could be a tool issue based on the following AR
https://www.xilinx.com/support/answers/52567.html
can you try to use 14.1 impact tool and see if this version is able to program
https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_LabTools_14.1_P.15xf.0.1.tar&akdm=1
Visitor sidh96
@kknI tried with the 14.3 version and it wont even detect the cable, and i have all the necessary drivers.
And for the SPI interface, it must be correct because i followed the instructions in the Xilinx documentation, and i took a look to the signal integrity of the SPI port and all the signals seem to be proper.
Visitor tuncsahin
Looking at the status registers your mode pins both seem high.
You should get the M1 mode pin to low for SPI Master configuration. If it is a custom board I would recommend pulling M1 pin down in your hardware design.
