Newbie limabean
How can we revert SmartLynq to use DHCP
I understand that the default behavior for SmartLynq is to use DHCP, and that we can configure it to use static IP if we want to.   We have successfully configured it to use a static IP address.   Now we need to return the device to use DHCP.   What are the steps to do this?   I see a 'update_hw_firware' command, which looks like it might place the device in the desired default state, but I do not want to risk moving away from the 2018.2 configuration that our team is using; I do not want to update to a later version.
Re: How can we revert SmartLynq to use DHCP
Use  update_hw_firmware -format -reset command  to make SmartLynq forget the old setting
Newbie limabean
Will this preserve the current version and not do an update? i.e. only a reset?
This command has update_hw_firmware so this will keep the firmware as per the Vivado version used.
