Impact 923 cable error
Hello!
I have problems with the ISE-IMPACT. When the ISE-IMPACT tab opens and I click LaunchWizard I find the following error: WARNING: iMPACT:923- Can not find cable, check cable setup.
When I connect the board to my partner's computer, the computer detects the cable and it is opssible to upload the program. I try to reinstalling the software, but this isn´t work.
I am using ISE Design Suite 14.7 and the operative system I have is Windows 8
If someone knows howw to solve this problem I would appreciate your help.
Re: Impact 923 cable error
You might follow this AR https://www.xilinx.com/support/answers/62380.html to install the ISE correctly. Once it is installed you can follow the driver installation driver https://www.xilinx.com/support/answers/59128.html
Harshit
