Observer @ida
JTAG programming of FPGA over SPI
I would like to use SPI to program a Zynq over its JTAG interface. In my project I only have an SPI available and unfortunatelly the mode pins on my Zynq are not accessible. Is it possible to "emulate" a JTAG over SPI? I looked at the JTAG signals with an oscilloscope and figured the clock is always constant and the data being sent, apart from the commands at the beggining, is the bitwise data of the bitstream. I would really appreciate some help on this.
Thanks!
Observer @ida
Re: JTAG programming of FPGA over SPI
Update: I ended up using the SVF Files generated from Vivado and a standalone converter for iMPACT to convert these files to *.xsvf, based on the xapp058 application note. By using the xsvf player it was possible to generate the necessary signals to program a Zedboard over IO pins. However, for an SPI only solution it is worth having an FPGA with the slave serial programming mode enabled - everything else becomes quite complicated.
I think it is not possible to "emulate" a JTAG over SPI by using ISE/VIvado tools.To know more details about Zynq device configuration please refer http://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf
Scholar u4223374
It should be possible. I've seen a range of projects where the SPI peripheral on a microcontroller is used for JTAG. Have a look at the Versaloon project; I believe it does this using an STM32 chip.
However, you will not be able to make it work via iMPACT or Vivado (or any other Xilinx tool) (eg. as a cheap alternative to a Platform Cable USB II). These tools are looking for specific adaptors, either Xilinx or Digilent models, and won't accept anything else.
Observer @ida
Participant dsingh
Hello @ida, When you mentioned "over IO pins", did you mean JTAG pins? Appreciate your response.
