Kintex7 configuration pin to BPI flash Memory
I want to know the physical pin that connects BPI flash Memory of configuration.
Please tell me the document.
I'm using the FPGA [XC7K410T-1FFG900] and [Micron flash Memory]. I change this Memory because flash Memory is out of production. I want to check my PCB's physical connection. However, I didn't get a list of FPGA's physical pin.
These documents didn't give me a pin list.
ds182_Kintex_7_Data_Sheet , ug470_7Series_Config , Plan Ahead
ug475_7Series_Pkg_Pinout , xapp587-bpi-fast-configuration ,
Best regards.
Franken_Ikeda
回复: Kintex7 configuration pin to BPI flash Memory
Figure 2-16, UG470. Then download the pkg file of the device you are using and find the physical number of each pin one by one.
https://www.xilinx.com/support/package-pinout-files/kintex-7-pkgs.html
