Visitor aniltirli
Partial Reconfiguration
If i create two or more partial reconfigurable block in the floorplanning in Vivado with same physical size and including same FPGA resources. Will the generated bit files describe the two regions in the same way? Can i load the same configuration to the two partial regions even if a configuration synthesised and implemented for one region in Vivado ?
Thanks in advance,
回复: Partial Reconfiguration
No you cannot do this.
The two regions actually have different coordinates, and the partial bitstreams generated will identify the coordinates.
