Possible to run previous version of hw_server?
Hi, I am running Windows 10 with two versions of Vivado 2018.3 and 2014.3.
I installed Vivado 2018.3 first and everything was working fine including hw_server. I was able to use JTAG no problem.
Then I installed Vivado 2014.3 and everything seems fine except when I open the hardware manager and try to open a new hardware target. I get the following:
WARNING: [Labtoolstcl 44-26] No hardware targets exist on the server [localhost]
Check to make sure the cable targets connected to this machine are properly connected
and powered up, then use the disconnect_hw_server and connect_hw_server commands
to re-register the hardware targets.
I already tried opening the hw_server from the 2014.3 directory manually and then trying to connect to the target but it does not work.
If I try the same with 2018.3 everything is working correctly.. So this made me wonder if there could be some incompatibility issues with running two different hw_server on the same PC even if they are not running at the same time. Or maybe 2014.3 hw_server is not compatible with Windows 10?
I would appreciate any suggestion on how to solve this.
回复: Possible to run previous version of hw_server?
https://www.xilinx.com/support/answers/54242.html
2014.3 does not support on Windows 10.
If both versions are supported on one OS, they should be able to work separately.
@iguo
Hi, thank you for this info.
I have now installed Vivado 2014.3 on Ubuntu 14.04.5 since it is supported.
I am now facing floating license issues but I will open a new topic for that.
