Voyager
Voyager
Problem with Cmod A7 JTAG
[@admins: haven't found an appropriate section so please relocate]
I've had a Digilent Cmod A7 35T for a while now, and it always caused issues when programmed from Vivado. I blamed this on bad USB cables, broken Digilent cable drivers and at some point concluded that the board is just defective in this regard.
Now recently I acquired a second unit and coincidentally installed a new system without any Digilent drivers, just Vivado 2017.2 and all the stuff that comes with it. To my surprise, the board works out of the box but shows the same unreliable USB JTAG connection as the other one. No need to say that I tried a bunch of different USB cables and different USB ports, but the result is always the same.
For example, running the XADC Dashboard with all channels enabled for some time will always result in ...
ERROR: [Labtools 27-2312] Device xc7a35t_0 is no longer available.
Check cable connectivity and that the target board is powered up then
use the disconnect_hw_server and connect_hw_server to re-initialize the hardware target.
Use open_hw_target to re-register the hardware device.
Note that there is no indication at the OS level that the USB device has any problems or got reset or reconfigured and the Cmod A7 does not reset or reconfigure either, so it seems like the Hardware Manager just got confused and somehow dropped the connection.
Any ideas how to debug and ultimately fix this annoying issue?
Thanks in advance,
Herbert
-------------- Yes, I do this for fun!
Scholar austin
Re: Problem with Cmod A7 JTAG
h,
One item you haven't tried:  the computer.  See if a different pc has has the same issues.  I had one of my dell laptops USB ports go flakey.
Austin Lesea
Principal Engineer
Xilinx San Jose
Voyager
Voyager
Hey @austin,
Good point, just tried with a different machine, but unfortunately the same result.
Best,
Herbert
Scholar austin
OK,
What bitstream are you loading? If the design exceeds the power supply's capacity, the Vccint may collapse, and you lose the JTAG link (may need to restart Vivado HWmanager.
Austin Lesea
Principal Engineer
Xilinx San Jose
Voyager
Voyager
Hey @austin,
I'm not loading a bitstream at all, I'm just running the XADC Dashboard.
But maybe the default demo code is over the limit.
Will test shortly with a minimal/empty design.
Herbert
Voyager
Voyager
Hey @austin,
Took a little longer than expected, but I finally got to test with a rather minimal design ...
    rgb <= (others => '1');
    blink_proc : process(clk)
        variable count_v : unsigned(23 downto 0) :=
            (others => '0');
    begin
        if rising_edge(clk) then
            led <= std_logic_vector(count_v(23 downto 22));
            count_v := count_v + "1";
        end if;
    end process;
... the RGB LED is turned off and the other two LEDs show the counter MSBs.
It takes a little longer for the XADC dashboard to fail on that one, but it still fails sooner or later with ...
[Labtools 27-2269] No devices detected on target localhost:3121/xilinx_tcf/Digilent/210328A41652A.
use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
Note that the loaded design and the USB connection itself is completely unaffected.
Closing and reopening the target doesn't really work (Hardware Manager goes into some kind of endless loop).
Killing or terminating Vivado and restarting it makes it work again and the Hardware Manager can connect without problem.
Herbert
Voyager
Voyager
Just tried with Vivado 2017.3 and the 'new' cable drivers.
Problem is similar, after some time, the XADC dashboard stops with zero values everywhere.
Vivado goes into an endless 'closing hardware target ...' loop.
XADC on Cmod A7
Any new ideas?
Thanks in advance,
Herbert
