Observer niooooo
SEM Controller - error injection address
I'm trying to integrate the sem controller and verify its functionality on a spartan 6 FPGA ( xc6slx45t )
SEM IP is in the repair mode。
On this page(https://www.xilinx.com/support/answers/61736.html) , the effective address range is 0000 to 1F0E。
When I use the following two addresses for error injection, the expected action does not occur.
On injecting double bit errors, the expected behavior is for status_uncorrectable to go high.
Inject Address = 0xC00000042
Inject Address = 0xC00000043
But if i am using the following addresses to injecting double bit errors .This status_uncorrectable  signal well be high.
Inject Address = 0xC01000042
Inject Address = 0xC01000043
Why is this happening?
回复: SEM Controller - error injection address
This is expected.
Spartan-6 has a very coarse structure compared to other device families; in fact, it's relatively hard even to find a single bit to inject error.
Do not try to understand S6's structure. If you can find one single bit to inject a error and it can be corrected, that means the IP is up and running.
Ivy
This is expected.
Ivy
Observer niooooo
Thank you very much for your reply. It is very helpful.
