Visitor kengie
SPI programming issue faced wth V7
I faced problem with programming the flash.
ERROR: [Labtools 27-3144] Invalild option : Byte 5959 does not match (00 != 02)
ERROR: [Labtools 27-3191] Flash programming Unsuccessful!
the mismatch byte is not the same everytime.
if i program the flash without verify, i am able to program successfully. i did verify_hw_device after program without verify. it reports that the readback data matches the programmed. what is the issue with the configuration memory verification?
i understand that there are other users posting regarding similar issues. However, i still could not solve my problem.
Any help?
Re: SPI programming issue faced wth V7
Hello @kengie
Are you able to configure FPGA successfully with same setup?
Please provide Tool Version and SPI Flash details.
Bhushan
Visitor kengie
i am using vivado 15.4, configuration memory is MT25QU512ABB8E12-0SIT and FPGA is virtex7 (7V585T).
i am able to download the bitstream into the FPGA device.
upon successful programming the configuration memory without verification, the FPGA is also able to boot up from configuration memory.
If the boot up is smooth and as expected, image has been programmed into flash correctly.
Saw similar issue; this may be a slight SI issue on the HW board. Verification does not show the correct result while reading back.
Hello @kengie
In this case try reducing cable speed it may help you.
Check UG908 (v2018.2) (Page 35~36) for more information.
Bhushan
