Newbie fenris
Spartan 6 Master SPI - same pins for configuration and data exchange
Hi, I am planning to design a board with MCU and Spartan 6. I wonder if it is possible to connect these two devices via 4 SPI lines and use the same pins for configuration and after loading the configuration for data transmission. Based on "Spartan-6 FPGA Configuration" I understand that the appropriate mode is Master SPI. And I understand that I should use MOSI, DIN, CCLK and CSO_B pins, which, after the configuration is finished, are generally available as User I/O pins. Then in the project I can have simply assigned SPI interface written in HDL code to those pins, which I can start using from the moment when DONE pin = 1. Do I understand this thing well? What else should I pay attention to? Have I not overlooked anything important? Can I ask you for advice to make this configuration as useful as possible and to design the PCB correctly? Regards, - fenris
Scholar drjohnsmith
Re: Spartan 6 Master SPI - same pins for configuration and data exchange
Can I clarify please,
Do you mean the fpga as slave or master ?
if its mater, it will try to read the flash at start up,
  if slave the fpga will wait to be written to,
Newbie fenris
I mean FPGA in Master SPI mode, so I understand it will start configuration after power-on or when PROGRAM_B is driven low. So it seems that my connection needs 6 lines: MOSI, DIN, CCLK , CSO_B, DONE and PROGRAM_B. I'm not sure about INIT_B.
I understand there is no Slave SPI mode.
Scholar drjohnsmith
You have this ?
https://www.xilinx.com/support/documentation/user_guides/ug380.pdf
page 18 shows the slave modes, the slave serial is often used to program the fpga from a MCU,
Newbie fenris
Ahh, you're right, Slave serial seems to be a more convenient mode. So in this case, e.g. considering Spartan 6 in TQG144 I have to connect:
- a MCU clock line to the IO_L1P_CCLK_2 pin
- a MCU data line to the IO_L3P_D0_DIN_MISO_MISO1_2 pin
and when the configuration is finished (DONE_2 is HIGH) I can use these two pins freely, so I can configure the SPI interface on them, does it agree?
Scholar drjohnsmith
dont forget the prog_b . init and done pins,
do us a diagram
