Spartan 6 slave serial configuration issue
We have SPARTAN-6 FPGA usually we will be configuring FPGA through JTAG, but now we are planning to configure FPGA with the processor, we are generating.Bin file from Xilinx ise software but referring to document Xapp502 a Perl script is required for generating.Bin file. Is really Perl script is needed to generate .Bin file for slave serial mode?
Re: Spartan 7 slave serial configuration issue
@sivakumarreddy50
   sorry it's spartan 6 using slave serial mode
No worries.  Slave Serial for Spartan-6 is described by Fig 2-3 in UG380.  Perl script will not be needed to reformat .bin file for Spartan-6 when using Slave Serial.
Mark
回复: Spartan 7 slave serial configuration issue
Are you asking for the perl?
https://secure.xilinx.com/webreg/clickthrough.do?cid=139211
xapp502 gives the link to download all the ref fils.
@sivakumarreddy50
Welcome to the Xilinx Forum!
Since you are planning to use the microprocessor in Slave-Serial mode (see Fig 2.2 in Xilinx document UG470) then PERL script is not needed to reformat the .bin file.
If you use Slave-SelectMAP mode then the PERL script is needed.
Mark
@sivakumarreddy50
Mark
