Visitor dsc5676
Spartan6 multi boot does it support compressing the bit stream?
in the document UG380, I found the following:
"Multi-Frame Write Register
The Spartan-6 FPGA supports Multi-Frame Write (MFWR) for first-time configuration but
does not support it during reconfiguration. The FPGA has to go through one power cycle
or use PROGRAM_B to reset the chip before MFWR can be used."
Does this mean I can not use compression for bit streams I intend to use for multi boot applications?
Thank you
Re: Spartan6 multi boot does it support compressing the bit stream?
you should be able to use the multiboot feature for the compressed bitstreams as well.
Let us know if you find any issues
