Visitor kikilinux
USB-JTAG programming cable
Hi all,
I have a NetFPGA-1G-CML board. when I connected FPGA by USB-JTAG programming cable, this cable became very hot. so I disconnected it very fast. Is damage my cable? What is the usual temperature of it when it is used?
Re: USB-JTAG programming cable
Hi Kiki,
what cable are you using?
Is it possible you once connected it wrongly and created a shortcut? (half the pins of a normal connector are grounded...)
Best regards,
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
Hi Kiki,
Best regards,
Dries
if you have another FPGA board, you can check the cable is working fine or not.
hope you are using platform usb cable, if so you should see green colour light on the pod led.
--Krishna
Visitor kikilinux
if my programmer damaged. it may my board damge also?
What is the exact brand and type of your cable?
Dries
