Unable to boot from QSPI
I want to run linux on zu19eg. In Jtag mode, it run okay. And i program the dual qspi flash successfully. However, there is nothing output when i power on the board.
I am sure the qspi flash is okay because it boot jffs2 rootfs from qspi flash successfully in jtag mode. And the same model flash is work well on zu9eg.
So what is the problem? Any suggestions are appreciated!
Re: Unable to boot from QSPI
Hi @yannantian198656
What is the mode pin settings when you boot from the QSPI? What is the error you receive when you fail boot from the QSPI flash?
Could you please clear on this statement? In JTAG mode, there is no boot from the QSPI flash.
Rohit
Thank you for reply. The mode pin is set to QSPI32. There is no message output when boot. But the PL CONFIG_DONE is low, and the FPS_ERROR_OUT is high.
