Visitor wongmatthew
Using legacy code with Vivado
We have a board which uses the xc7k325. The .bit file we have is meant for a xq7k325. Previously, we programmed this FPGA with Impact 14.7 without problems. When programming with Impact 14.7, it notifies the user of the difference but still successfully programs the FPGA. However, Vivado gives us the "Unsupported part xq7k325tr900" message when trying to program. Why can Impact 14.7 program the FPGA but not Vivado? How can we get Vivado to successfully program the FPGA despite the apparent incompatibility?
Scholar drjohnsmith
Re: Using legacy code with Vivado
just check which version of vivado your using and is that part supported in it,
Also I think, the lab tools version of vivado 'can' program anything,
but it could be that the vivado programmer is being clever and recognising the part ID,
Hello @wongmatthew
It's not recommended to use same bitstream file for different grade (for example: commercial and Industrial grade) FPGA device even though it is working for you. As this can cause timing issues on hardware.
You should regenerate bitstream for your design according to your device.
This https://www.xilinx.com/support/answers/24245.html and https://www.xilinx.com/support/answers/54561.html answer records might provide you some idea about timing variation between different grade of FPGA.
Bhushan
Scholar dpaul24
@wongmatthew
In which category does this part xq7k325tr900 fall into? I mean Xilinx 6 series, 7 series, etc?
To me it looks like a "less than 7 series FPGA" since it could be successfully programmed using ISE14.7/Impact.
Now Vivado is meant to be used for Xilinx 7 series FPGAs and higher-class FPGA families. This might be the reason why Vivado refuses to recognize the part xq7k325tr900.
FPGA enthusiast!
All PMs will be ignored
Which version you are using for Vivado? Is this a ISE generated bitstream? If so can you try to use the below paramter and see if it programs successfully. There was some issue with the ISE generated XQ device bitstream and it was fixed in 2018.3 release. Either use 2018.3/2019.1 or use the below parameter before assigning the bitstream.
> set_param xicom.use_bitstream_version_check false
Again it is not recommended to program the different device bitstream to different device for which bitstream was generated.
Harshit
Visitor wongmatthew
I'm using Vivado  2018.3. Unfortunately, I didn't generate the bit file because the code was written years ago by a different company. The source code also is not available. I just have to work with what I have. The parameter change might work.
Since its a non-SSI ( multi-SLR) device, you can try to see if bin file works. I am assuming its an issue with header which have XQ in there & Vivado is comparing it with XC device. Else you can use the above parameter, Hopefully it should work.
-harshit
