Visitor ndnsoulja
VCU118 - Indirect programming not working
Hello, I can't load a build into my VCU118 since I set the CFG_AES_ONLY bit in my eFuse. Is there any other way to load the flash and not through FPGA?
回复: VCU118 - Indirect programming not working
It means FPGA can only accept encrypted bit now, with the key you set early. No matter which config mode you are using.
Vivado loads a system bit ( you have no access to this) into fpga first and this bit's work is to program the flash with your MCS. Since this bit is not encrypted (of course!), it cannot be sent into fpga now, so Vivado cannot program your flash. Does that make sense?
Vivado needs to load a specific design/bit into fpga first and then use it to burn flash. Once you set the security bit, you can only load an encrypted bit with the key. So no, you cannot use Vivado to burn the flash any longer.
Now you can only use some off-line 3rd party programmer to burn the flash ( you need to take off the flash from board or use some flying wires to access it), and the image should be encrypted first with the key you set in eFUSE.
It's very improper to set this bit on a DEV board.
Visitor ndnsoulja
" Once you set the security bit, you can only load an encrypted bit with the key. So no, you cannot use Vivado to burn the flash any longer. "
So does that mean I can only load encrypted bitstream to the flash via JTAG? OR does that mean the FPGA can only load from the flash but we won't allow the flash to be programmed via JTAG?
Visitor ndnsoulja
Yes, thank you for the clarification!
