Vivado: How to generate a .bin file
I have a non-project mode TCL script.
I generate a .BIT file using the following"
write_bitstream -force $projectDir/bitstream/basedesign.bit
I then generate a .MCS file using:
write_cfgmem -format mcs \
             -interface bpix16 \
             -size 128 \
             -loadbit "up 0x0 $projectDir/bitstream/basedesign.bit" \
             -file $projectDir/bitstream/basedesign.mcs
Both works good.
Now, I would like to generate a .BIN file. (It's a bit file without the header.)
How? I cannot find in the literature where it explicity tells one how. All the forums
talk about ISE. This is Vivado not ISE.
Is there an option for write_bitstream? I haven't read about it.
Swimteam
Re: Vivado: How to generate a .bin file
Yes. You can use write_bitstream -bin_file else you can set that option in bitstream settings. Here is the snapshot:
Thanks. I apparently missed that option reading ug835 (v 2012.4) Dec 18, 2012.
I also found that the syntax cannot include the extension like .bit or .bin. The tool complains. Also found that you have to use the -force option or else the tool complains.
But it works. Syntax I used was the following:
write_bitstream -force -bin_file $projectDir/basedesign
