What happens to non-utilized LUTs after programming ?
Hi everybody,
May I know what actually happens to the LUTs and registers that I am not utilizing in my program, after burning the FPGA with the bitstream? I am more interested in 7-series and + FPGAs. Since the bitstreams are always of same/similar size for that particular chip, I think Xilinx writes something to those un-utilized registers and LUTs while programming. I assume remaining SRAMs are initialized to reset condition (0) ? May I know that , if that is not a trade secret.
Goutham
Scholar austin
Re: What happens to non-utilized LUTs after programming ?
G,
The memory is designed to power on INTO the '0' state.
The startup programs every configuration memory cell from the bitstream, used, or unused, every bit is represented by a value appropriate to its use, or if unused, again '0'.
So, unused configurations starts at '0' and is re-written as '0' by the bitstream.
Why so interested, if I may ask?
Austin Lesea
Principal Engineer
Xilinx San Jose
Hey Goutham,
Your assumption is correct, the majority primitives (LUTs, FFs, MUXes, etc) are initialized to a default (0) value which can be easily seen in the bitstream which contains large amounts of zeros when you only utilize a few of those resources. It is probably similar for the routing resources and I/O pins, although the default state there might not always be zero. I don't think it is a trade secret, but let's see what Xilinx has to say about it ...
Best,
Herbert
Scholar austin
G,
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi @austin and @hpoetzl
Thanks for confirming my assumption. I am doing a research on low-level custom routing in FPGA and thats when this question popped up. Thanks for your time.
Goutham
