Observer amassa
Windriver Install Problems
I have a zedboard and am running SDK 2018.3 on Windows 10. I have tried numerous different methods to try to get the Jungo WinDriver to install but have been unsuccessful including the manual installation as described in
https://www.xilinx.com/support/answers/54381.html
I am able to get a Jungo device to show up in my device manager, but cannot complete the install of the WinDriver. The Jungo device shows "Unknown device". I have tried updating the driver to the xicom\cable_drivers\nt64\dlc10_win7, but that does not work either.
Not sure what else I can try.
Thanks for any help.
Re: Windriver Install Problems
Hello @amassa
Did you tried installing driver as per AR# 59128?
If above method does not work then, Perform all steps provided below for installing driver in Vivado:
  1. Make sure Platform Cable USB is unplugged
  2. Open a Windows cmd.exe prompt as Administrator
  3. In a command prompt browse to " <Vivado Install Directory>\data\xicom\cable_drivers\nt64\dlc10_win7"
  4. To uninstall type the command: wdreg -compat -inf %cd%\windrvr6.inf uninstall
  5. To uninstall type the command:  wdreg -compat -inf %cd%\xusbdrvr.inf uninstall
  6. Run command: net stop XilinxPC4Driver
  7. Delete with command: %WINDIR%\system32\drivers\windrvr6.sys
  8. Delete with command: %WINDIR%\system32\drivers\xusb*.sys
  9. Delete with command: %WINDIR%\system32\drivers\xpc4drvr.sys
  10. To reinstall type the command: wdreg -compat -inf %cd%\windrvr6.inf install
  11. Plug in USB cable
  12. Go to Windows Device Manager. Look for 'Jungo'. Make sure it says 'WinDriver' under Jungo
If not, right-click and select 'Update Driver Software'.  Select 'Search automatically for updated driver software'
  1. Go back to CMD prompt (With plugged in USB cable)
  2. To reinstall type the command: wdreg -compat -inf %cd%\xusbdrvr.inf install
  3. Programmer status light should turn on and be green, if attached to target
  4. Run 'Cable Auto Connect' to verify
Bhushan
Observer amassa
Thanks for the response @bpatil . I did try the AR#59128 sequence. The problem with that is that if windrvr6 is installed, it removes it.
I've come across the sequence you listed as well. It didn't work in that method for me when I tried it. I was finally able to get windriver to install under jungo and then had to restart my system, then install the usb driver.
