Xilinx Platform Cable USB II vs HS3 Digilent
I am wondering which JTAG to buy, Xilinx Patform Cable USB II or HS3 Digilent ? Although this topic has been discussed earlier on this forum but there are mixed reviews. Some suggest Xilinx Patform Cable USB II while other suggest HS3.
There is one review from 2016 which suggest to buy HS2 instead of HS3. I don't understand this completely. I guess HS3 is upgraded version of HS2 and if the price is same then why not HS3 but another review says that HS2 cable does not support the SRST signal which may be required when debugging over JTAG. Do we have SRST in HS3 ?
Technically what are differences between Xilinx Patform Cable USB II or HS3 Digilent ? Is there any feature missing in terms of Programming and Debugging in HS3 Digilent compared with Xilinx Patform Cable USB II ?
The requirement is to Program ZYNQ 7Z20 MicroZed Board and Debugging.
Re: Xilinx Platform Cable USB II vs HS3 Digilent
Hi @joniengr081,
Main difference the Speed, cost and Size. HS3 Digilent cable is better.
In Smart Lynq cable you can go upto 40MHz. whereas in HS3 digilent you will get max 30MHz.
PS_SRST Supported in HS3 Digilent. For more information refer page 5 of this link https://reference.digilentinc.com/_media/jtag_hs3:jtag-hs3_rm.pdf
Deepak D N
please reply or Give Kudos or Mark it as an Accepted Solution.
Hi @joniengr081
Have you gone through the below link? If not, check if it helps you as there are some key pointers given by our Xilinx super users:
https://forums.xilinx.com/t5/Design-Tools-Others/Platform-Cable-USB-II-vs-Digilent/td-p/783329
Rohit
Hi @joniengr081,
Deepak D N
Advisor evgenis1
Advisor
Hi @joniengr081,
I've been using Digilent cable for pretty much entire feature set Vivado supports: programming bitstreams, debug using ILA probes, Ibert, and embedded software. I haven't seen any feature that is not supported by Digilent. It is much faster than Xilinx JTAG, has smaller form factor, and also much cheaper.
One disadvantage worth pointing out is that Digilent has straight JTAG connector. I needed right angle connector for some of the boards, so I managed to rework Digilent.
Evgeni
