Observer logicaledge
ZU6 sometimes identifies as ZU9 in Vivado HW Manager
My ZU+ device is the xczu6eg-ffvb1156 device, marked as such on the device package. When I connect to the board with Vivado Hardware Manager, it connects reliably via JTAG, but sometimes the device identifies as a ZU6, but other times as a ZU9. It happens with both Digilent and Xilinx programming cables, and at multiple JTAG clock frequencies including the slowest options available.
Any ideas? Has anyone else seen this behavior?
Kevin
Re: ZU6 sometimes identifies as ZU9 in Vivado HW Manager
Hi @logicaledge
which Vivado version you are using ?
Please share the snapshot of IDCODE read from the Vivado hardware manager when you connect the device.
please refer this https://www.xilinx.com/support/answers/67381.html, helpfull for your query.
regards,
Deepak D N
Please Reply or Give Kudos or Mark it as an Accepted Solution.
Hi @logicaledge
Check following possible causes of Zynq UltraScale+ (not Zynq-7000) device reports an incorrect JTAG IDCODE when identified by Vivado HW Manager
  1. PS_REF_CLK must receive a free-running clock source that is within operating specifications. (If there is no clock running, then the IDCODE might fail, as well as other device functionality.)
  2. PS_POR_B must be de-asserted when scanning for the JTAG IDCODE.  (The JTAG TAP works when PS_POR_B is asserted, but a returned IDCODE might not be right.)
Bhushan
Hi @ddn,
I am using Vivado 2018.2.
Kevin
Thanks, @bpatil - the note about POR assertion may be relevant to what we're seeing. We're investigating further and will update this thread if we can confirm.
