Visitor neildharris
Zynq QSPI Flash - How can I program stand-alone (w/o SDK)
I've finished my development cycle, and have a .BIN file that works.  I'd like to send it over to production with the necessary software tools and a JTAG cable so they can program the QSPI Flash on our production units.  Platform is Windows7, and I would like to keep it as simple as possible (avoid installation of Vivado/SDK, etc.).  Tried program_flash at the command line with no success.  Anyone have any success doing this?
Scholar sampatd
Re: Zynq QSPI Flash - How can I program stand-alone (w/o SDK)
Are you unable program the flash or can program the flash and not boot from it?
What commands did you use ?
Visitor neildharris
There is no problem programming the flash memory if I issue the command (see below) from within the SDK.  I don't want to put SDK out on the production floor, so I'm looking to create a simple, (one-step?) procedure that will program the flash via JTAG, but without installing or invoking the full SDK.  Is there a way to utilize the batch files or shell scripts without bringing up the IDE?  Any help would be greatly appreciated.
The command I use within SDK is:
cmd /C program_flash -f BOOT.BIN -offset 0 -flash_type qspi_dual_parallel -blank_check -verify -cable type xilinx_tcf url TCP:127.0.0.1:3121
I am experiencing a similar issue, so a reply would also be appreciated.
One alternative to program the QSPI flash "lighter" than the SDK is the Lab Tools application, but it does not directly accept a .BIN file.
Visitor eurecam2005
You could program flash without starting GUI using utilities which are bundled with SDK.
In Linux utilities required are installed in /opt/Xilinx/SDK/2015.4/bin/
Some adaptations might be required for Windows
You need first to start an hardware server :
/opt/Xilinx/SDK/2015.4/bin/xsdb
Connect to the target :
xsdb% connect arm hw
Then you could program your flash with program_flash
The nice thing is you could run the command inside xsdb (at least in Linux) which avoid starting a second shell. For example :
xsdb% /opt/Xilinx/SDK/2015.4/bin/program_flash -f BOOT.bin -flash_type qspi_single -verify
Finally disconnect from xsdb :
xsdb% exit
To make everything work in a script I had to add exec to run program_flash and puts to display results of the programming :
connect arm hw
set ff [exec /opt/Xilinx/SDK/2015.4/bin/program_flash -f BOOT.bin -flash_type qspi_single -verify]
puts $ff
exit
This solution certainly could be improved
If you want to avoid both Vivado & SDK installation then you can go for U-boot.
So, you need to load U-boot on Zynq PS and then you can program QSPI through U-boot.
Please refer to http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip for help.
I don't feel like any of the answers given address the question at all.  I am preparing for the same thing.
I don't want SDK on the production computer, just a simple little program.
UBoot is not a solution.  FIrst, my application is bare mettle, so UBoot serves no other purpose.  But more importantly, SDK is still required to put UBoot on the board to begin with, and the point is to program boards on the production line that have never been in the lab.  Its this little thing some of us do called manufacturing.  Surely there must be a simple stand alone utility that an assembly line tech can run 50 times a day.  In my case it needs to recognize a JTAG-HS3 and a .mcs file and put the latter on a QSPI using the former.  I recognize that the details get a bit messier, as it involves loading a program into OCM and running it as an "interface", but it is still a relatively simple task that should not require Gigabytes of disk space and an arcane command line or ten layers into a complex program designed to do much more and capable of creating mistakes on the assembly line.
SDK isn't even terribly viable in production, because one has to have a project before one can flash a PROM.
And just to forestall any other boondoggle side trips, at least my application does not have an SD socket, so bootstrapping via SD isn't a viable approach.  Also, although it shouldn't matter, at least some of our projects don't have DRAM.  We're talking some small boards with little besides a PS, QSPI and Zynq.
Observer zafirhafeez
Did you managed to find a solution to the problem. I am facing exactly the same situation like you have mentioned and require a small utility for downloading the bin file to spi flash on production line boards. The need to install huge vivado software just for downloading bin file seems absolutely absurd. Is there a better solution?
Observer ganaylor
It is surprising that after so long, this issue does not have an acceptable answer - nor has Xilinx stepped in to inform us on how to perform what must be a very frequently required task (like for every deployed Zynq based device!). Reassuringly however, there does appear to be an answer. The recent versions of Vivado Lab solutions (at least from 2016.2) do allow a BOOT.bin to be loaded on to the configuration flash memory from the GUI by selecting 'Open Hardware Manger', click on 'Open Target' in the green bar and then choosing the 'Tools' menu bar tab and then 'Add Configuration Memory device' > <ref to Zynq chip>. Select the flash family/part to be programmed (including the correct spi width) and then OK,OK. Select the correct boot.bin file with the ... button level with Configuration file (don't need fsbl if the fsbl is already in the .bin file). Leave erase, program and verify checked, OK - done....
Thanks for that tip.  I have downloaded it and it appears to be exactly what I'm looking for.  (Well a bit more than I'm looking for, but certainly meets the requirement).
Visitor jrbrizo
I have the same problem. I'm trying to look for a way to program Zynq without installing the SDK. I tried the recent version of Vivado Lab solutions but it does not support the SDK where we did the development (2014.3 - and we have no plan to use the latest). Is there any other way to do it? I did a script to automate the flashing but it relies on the SDK.
In Vivado 2017.3 Hardware Manager, you do need to include fsbl; it will not allow you to leave it blank, even if the fsbl is included in boot.bin.
Yours is the method I am using to try to boot, but my question is more related on how to generate boot.bin. If I have an fsbl, a bitstream image, a u-boot.elf, a rootfs.tar.gz, and a bootable kernel image zImage, how can I generate a working boot.bin from that?
I generated a bif file to create this binary that looks like this
image : {
        [bootloader]zynq_fsbl.elf
        u-boot.elf
        [load=0x2a00000]system.dtb
        [load=0x2000000]rootfs.ext4.gz
        [load=0x3000000]zImage.bin   // currently bootgen requires a file extension. this is just a renamed uImage
I tried loading boot.bin as the configuration file (.bin) in the Hardware Manager and the zynq_fsbl.elf as the fsbl. The INIT LED went green, but it never hit u-boot and the green DONE LED never went on. In the terminal there were no messages displayed, neither u-boot or kernel.
